Gaddy09tahoeltz
- Joined
- Nov 28, 2023
- Posts
- 6
- Reaction score
- 14
Hi guys, new here and first post- that being said if i screw something up Edi quite wise please let me know respectfully.
My 09 POS is throwing a U00730 in the TCM.
-This code is mapped on the Tech 2 screen as a code against the physical device. A lost communication DTC typically is set in modules other than the module with a communication failure.
-I can communicate with all the modules and do bidirectional testing' everything seems fine.
Im also setting a B1001-46 Option configuration error in the VCIM
B1001 Chevrolet Code - SDM Option Configuration Error
-I have no airbag light on.
-When i go to configure the SDM in the BCM it says the numbers match and is not needed.
Parts replaced to this point-
-Negative battery cable- broke almost in half at R/F frame ground point.
-Fixed chaffed wire for the ect sensor on top engine harness.
No fix yet. I've gone through all the wiring for chafes, broken or pinched wires per TBS
I'm at a loss and could use a few ideas bounced around.
thanks in advance
U0073 Code: Control Module Communication Bus “A” Off
I found this in one of GM upfitters wiring books online-This code is mapped on the Tech 2 screen as a code against the physical device. A lost communication DTC typically is set in modules other than the module with a communication failure.
thanks in advance
