2007 Tahoe LTZ Power Liftgate opens but does not close
Ledesordre
Recently replaced the button on the inside of the door that is supposed to close it.
Cannot get it to close using the interior button, the fob button, or the liftgate close button.
Lifts up just fine, any ideas? Not critical but it would be nice to get it to work.
Ledesordre
Ledesordre
Check the wiring going into liftgate it gets chafed
Checked it. Seems okay. Is there a specific wire that we know of that controls the gate closing specifically? If i knew what wire I can probably test the integrity of it.
Big Mama
Virginia
There’s a harness behind the panel. The panel is a booger to get off but once it is you’ll see everything. Go ahead and check everything in there including camera you don’t want to do this twice.
Ledesordre
Ledesordre
Thanks
I’ve got the interior trim panel off if that’s what you mean. Wiring as far as I can tell seems a bit tight but looks intact. Need to check more thoroughly after this rain stops.
Big Mama
Virginia
And check the activation from all sources key fob roof mounted panel and outside panel. My button inside sticks from time to time not allowing my fob to work.
Ledesordre
Ledesordre
Outside panel works great to open it, not close it
Interior button on drivers area ceiling works great to open it, not close it
Fob hatch button works great to open it, not close it
Thanks again all
Big Mama
Virginia
Ok sounds like the problem is in the rear hatch button. You may be able to disassemble it and clean the contacts. The switch gets wet and full of crud being outside. If it’s not serviceable a new one is fairly inexpensive.
1Possumcop
