SherylInKS
Been having issues with Traction Control and Stabilizer Warnings on dash. an AZ guy asked me what else beside the Traction Control and Stabilizer lights coming on is an issue. I TOLD HIM the brakes need done and it feels like The "ebrake is sorta on or it has a collapsed rotor". It is not Road Drivable .... just been able to move it around in the driveway. HE SAID sounds like You more than likely have your bake pad jammed between you caliper and rotor. I asked him and he is a mechanic in AZ and also works on his own stuff. We HAVE CHANGED ALL the other stuff that is suggested to fix Warnings (in the last 6 months) and nothing has changed. So thoughts on >>> HE SAID sounds like You more than likely have your bake pad jammed between you caliper and rotor. TIA.
