2006 Tahoe/Locking brakes )car won’t move
B-train
You most likely have a hose that is collapsing and causing a check valve situation - holding pressure at the caliper.
Or, you have a caliper that isn't retracting when it gets warmed up - sticking piston. It could also be caliper slides, etc.
Another option I can see is that the master cylinder is overfilled and when the engine bay warms up, the fluid expands and has nowhere to go, so it pushes on the calipers.
There is a possibility the ABS module is holding pressure on a circuit for some reason as well. Have you tried unplugging the ABS to see if that changes anything? Or, you can try a couple ABS stops on a slippery surface and see how it acts afterwards.
Kungfubenny
Hello did anyone ever figure out what's causing the brakes to lock up while driving...i am having this same issue i explained to my mechanic the issue and he said that it was the master cylinder so we went to oreillys and purchased a brand new master cylinder it seem to have fixed the problem until about a week later it started doing the same thing about 10 minutes into driving the vehicle i can feel it starting to slow down so I'm giving it more gas to try to keep a steady pace with other vehicles but it's like I'm mashing the brakes and the gas at the same time...so i found some information on Google where a guy was having the same problem and he said that when his would lock up he would pull over and get out and loosen the lines that go to the master cylinder so last night as I'm driving my tahoe z71 it starts to act up so i pull over get out and loosen the lines on the master cylinder and let the pressure off of the calipers i tighten the lines and I'm able to move again freely until about 15 to 20 minutes it does it again if anyone has any info on how to fix this issue please chime in my name is Jeffery my email address is [email protected] just in case anyone wants to reach out to me...thanks in advance
I’m having the same issue, so far I’ve changed abs sensor in the rear left tire, and the wheel hub/bearing of front right wheel.
I’ve pulled the abs fuse as well to no resolve.
My next moves were to address the master cylinder and brakebooster. If you are able to find a solution please let me know I’ve been trying to get my truck back on the road for almost a month.
If learn or find a solution I will be updating this thread.
See post #11 (by @B-train) in this thread. Sounds to me like a hose might be collapsing or a caliper not retracting.
rockola1971
Indiana (formerly IL)
Your master cylinder and booster are not the culprits here. Everytime you crack open a brake line connection you are letting air into the system. That is a no go. The brakes will have to be bled....but likely they will need bled anyway AFTER you replace the collapsed rubber brake hose that is causing your problems or replace/rebuild the bad brake caliper that is not retracting.
Put it back together. Drive vehicle until it starts acting up and hit each brake rotor with a IR thermometer (they are cheap at harbor freight) and the rotor(s) that are the hottest out of all of them is the problem wheel. Check the problem wheel(s) for collapsing brake hose and caliper sticking and not retracting. You can do both of these inspections with the problem wheel jacked up off the ground and tire removed. Have someone push on brakes with engine running and watch what the brake hose does and see if it is collapsing. Check that brake caliper squeezes the rotor and the slightly retracts when brake pedal is released. There is a remote possibility that your ABS manifold is at fault here but not the common fault that happens.
Kungfubenny
Very logical analysis! The caliper piston in the rear had completely shattered due to depleted brake pads. It release most if not all of the brake fluid. Upon realizing this I replaced the caliper and the presumed amount of brake fluid. All pads are new front and rear.
I did need to bleed each one to be able to pressed the pistons in just in order to be able to set them in place over the brakes pads.
*which I thought was odd being that I’ve never had that experience during a brake change*
Before bleeding each brake the pistons would protrude even after applying pressure to push them inward via c clamp they’ d push themselves back out.
chiefable
