2004 Yukon rear wiper problem
Stevo1975
Hello all,
Brand new to the forum, and I could use some help with this one. I had to replace the rear wiper motor and arm (just did it today), and I still can't get this to work. With the wiper switch on 1, the wiper lifts up out of the "holster", but won't do anything else. Here's the weird part. When I flip the switch to 2, the wiper simply goes back into the holster. I'm at a loss on this one. I got the old wiper motor to work for a while by turning it on and gently "assisting" the wiper arm, but now I don't know what the problem is.
S
Stevo1975
Brand new part. Matching part numbers. Funny, the one that I took out was made in Mexico.
MrBalll
West Texas
Did any of the wires look stripped or pulled on the connection from the vehicle?
S
Stevo1975
Not really. I also checked the connection that passes through to the inside of the vehicle - no burnt wires. I could probably pull the connector off the wiper motor and inspect it a little more thoroughly.
shreksbrother
Auburn Hills, MI
What about when you push the switch in (the washer)? Mine does not work at all in position 1 or 2, but is happy to wipe 3 times when I push it in... I keep meaning to look into it but forgetting.
Maybe it's just a defective replacement motor, or was mislabeled as correct for your vehicle. I'd return it.
S
Stevo1975
I'll pull it out and run jumper wires to the battery and see if it does the same thing. Only way to be sure.
ScottyBoy
Shreveport, La
I vaguely remember a TSB somewhere about the rear wipers on the NBS SUVs. Something about a bad ground on the wiper controller under the hood? Or a bad ground on something. I do remember that the solution was to add a ground wire.
murk3d
