2000 Yukon SLT Pigtail Harness Diagrams - Chiltons/Haynes Electrical Service Manual NEED HELP !!! 24 pin Wiring Harness’s and 9 pin Harness
WorkCon
These are all messed up and not connected properly. Also need PCM diagram pinout diagram for 2000 GMC Yukon (New Body style) with Amp NO BOSE Stereo
Thank You
You'll likely get better responses if you detail which harness connectors are in play, apart from the PCM connectors.
Might want to subscribe to AllDataDIY or similar.
Thank You
you'll probably have better luck searching 2001 or even 2002
2000 was a year they made obs & nbs, so much mixed info out there, searching a later year is always a better option.
just keep in mind changes were made in 2003 so that can lead you wrong as well.
not sure what you are trying to accomplish, the base gm radio amp is behind the glove box.
a good point of reference may be a junk yard for a hands on look for correct wiring. you could even cut out what you need or take pictures.
W
WorkCon
Yeah I was thinking that same thing but don’t live close to one that might have one. And if so not modified already. Seen lots that have might just have to go buy a manual
Hobert
Downers Grove, IL
fermonarez
