1999 Tahoe Starts fine, then runs rough
Magpie0663
Starts fine, then runs roughAfter a few seconds. If I shut it off and restart it it will run fine for 10 seconds and then run rough again. I have already installed the air fuel sensor in the throttle position sensor also cleaned the MAF sensor.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Yea, any CEL? Even an engine that has a misfire can start and seem to run ok for just a little bit. Is the running problem in park or in gear?
Hoesgottaeat2
Western NY
Greetings, and welcome to TYF.
Over the years I have had a couple of items fail on me that produced similar symptoms on mine…
- EGR valve
- Idle air control valve
Most consistent with symptoms you mentioned in my experience was the idle air control valve. A few times I was able to just remove it, clean it with some carb & choke cleaner and reinstall. Issue resolved.
montanaboy65
