01SLE
- Joined
- Mar 22, 2014
- Posts
- 71
- Reaction score
- 18
Hi, I'm new to this forum and unfortunately my first post is not about how great my truck is lol. I just picked up a 01 Yukon 5.3l 4speed this weekend and I knew ahead of time it probably needed a rear main seal. Prev owner said oil pan but I know better. Oil is leaking pretty profusely from between the pan and bell housing and splashes back onto the trans and exhaust while driving. While parked and turned off, some oil leaks out but not much after sitting a while. Sucks but at least it's a cheap fix if I'm willing to sacrifice a weekend under the truck.
Last night I noticed another issue. The oil pressure is sitting about right from what I can tell at idle, ~35psi. But it "searches" a lot. It's wobbling as much as 5psi up and down at idle fairly rapidly and doesn't get much higher than about a little over 40 at higher rpms.
In the past ~5 years I've had an OBS 07 Silverado 5.3, 08 Silverado 5.3, and 09 Yukon Denali 6.0 and none of them had the oil pressure bounce around and from what I remember and at higher rpms while accelerating, the oil pressure would raise at least towards the ~60 mark.
Also when I started it for the first time, the check oil pressure light came on and as I thought "oh !@#$!" and went to turn it off, the oil pressure jumped up to where it was supposed to be. Nerve racking...
So basically I'm wondering if these pressure symptoms are related to the main seal leak, the oil pump, or something else. Obviously if i'm going to pull the transmission I'd like to replace everything that may be messed up at once. Or if you guys know anything to check before I dig into it, let me know. Thanks!
