t.stimpson
- Joined
- Nov 16, 2010
- Posts
- 227
- Reaction score
- 24
I honestly have no idea. But I have noticed when looking through the options that the 22" wheel option is only listed on the rear shocks, not on the fronts. Not sure why but thats what I noticed. If you go to rockauto.com and look up your vehicle. It will list the front and rear shock absorbers with a suspension code listed next to the different parts. I would suggest you look and see if any of those codes are listed on your sticker in your glove box. That sticker tells you which suspension system you have. Mine was Z55. This explains it better. http://www.shockwarehouse.com/news/gm-suv-suspension-decoder.cfm. So if your sticker says Z55 then I would think it would be the same regardless of wheel size in the front, it might be only the rear shocks that are differnt. But again, I'm no expert. this is just what I have found out.
