Escalade Roof Rack Part Numbers with Diagram
adventurenali92
Big Bear Lake, ca
I get that...and I have the cross rails installed.
I'm asking if they can be on the wrong side. As it sits, I could take the chrome side rail from the left side and flip it 180* front to back and put it on the right side. That's what I'm asking about. I wasn't careful enough to hold them up together to discern if there was a proper front to back orientation or if it didn't matter.
Yes they are front to back specific. They cant be reversed and put on the opposite side. The longer plastic end caps need to be up front with the shorter end caps at the back. Otherwise the mounting holes and the center anchor nuts will not line up. The center anchor nuts will only slide into place under the rails one direction to hold the side rails correctly in place.
Slammedchevy01
Does anyone have the screw size for the crossbar to attach to the rail mount?
Mine were bought online and the crossbar mounts were left on rails and the C/bars shipped separate.
Brian12019
