4l60e performance upgrade stage 2 - $475
Sasquatch
Orange County N.Y.
i was on craigslist and came across this and thought someone here might be interested. link for pics.
http://hudsonvalley.craigslist.org/pts/1360270012.html
i might be selling the silverado ss but before i do i would like to try and cash in some performance parts i have bought but never installed.
-brand new 2800 stall torque converter. kevlar lockup clutch. paid 450 plus shipping for this. this is good for engines up to 500 hp. it is also 4 pounds lighter than stock for more power to the wheels. this converter comes with a full ONE YEAR WARRANTY. not a cheap 90 day that most of the converters come with. that alone tells you that is built with quality!
High Performance Torque Converter
New Bearing
Closer Tolerance
New Burnished Hub
Cleaned Mounted Surface
Verifed Pilot Size
New Lock-up Clutch
Upgrade Turbine Hub
Reinforced Mounting Hub
Insured Thread Conformance
Reinforced Impeller Hub
Reinformed Dampners
Highest Quality Welds
Balanced
Brazed Impeller
Brazed Turbine and Steel Splines
-transgo hd2-c performance shift kit (includes springs, boost valve, EVERYTHING)
-TCI .490 boost valve
-beast sunshell
-heavy duty transmission cooler (plate and fin style) brand new atleast twice the size of the stock cooler
-gm chrome deep transmission pan (2 quarts more than stock pan)
-sonnax forward pinless aluminum (not cheap plastic) accumulator piston
i would like to sell the whole kit as a package deal this way someone can get a slamming price on a full transmission performance upgrade. figure $475
for this whole package (thats what i paid for the torque converter alone and about half of the total amount spent on this package)
all these parts are brand new and ready to go. they will fit 4l60e and 4l65e transmissions found in gm chevy silverado 2x4 4x4 awd escalade sierra denali etc. doing this upgrade will not only increase transmission life but will also take between .75 to one full second off 1/4 times.
i can only fit 4 pics on here but everything is packed and ready to get installed!
BOSS
The People's A D M I N
Dallas
Not bad, torque converters can be spensive, good deal :waytogo:
02z71hoe
Pikeville, KY
4l80e?
has anyone converted over to a 4l80e?
i can't get a built 4l60e to hold up!!!!!
02 5.3l
Shortuned
cam
longtubes
off road y pipe
cold air
z06 tb and mass air
BOSS
Dallas
02 5.3l
Shortuned
cam
longtubes
off road y pipe
cold air
z06 tb and mass air
Wow way to dig up the past :)
It seems strange that you don't have a SC or turbo and you are breaking built 4l60e's? Are you taking it to the track?
B
02z71hoe
Pikeville, KY
No track use yet. I can't keep one in long enough to get to the track. Maybe some grudge matches on the street.
Max
Mile High
Denver
Built 65 will hold boost+cam around 500ish whp but it all depends on the driver.
JKmotorsports
Austin, TX
02 5.3l
Shortuned
cam
longtubes
off road y pipe
cold air
z06 tb and mass air
Then someone isnt rebuilding your tranny properly or cheap parts are being used. Are you breaking hard parts (sunshell, planetaries, etc) or burning through clutch packs? A properly built 4l60(5)e will hold up to your mods with no problems.
JKmotorsports
Austin, TX
...while the 60 has four pinion planets, for those wondering.
Also, I believe the 65 has a hardened sungear, input shaft, and output shaft.
The rest of the internals are basically the same and the outside is exactly the same as well.
Jsimon
