Seatbelt chime
Is there a way to turn off the seatbelt chime? IE the alert when you're not wearing your seatbelt?
coffeyman76
The only method I know of is to fly through the front windshield. That should keep it quiet.
:jester:
yates ™
Resident Apple hater
Iowa
Go to a junk yard and cut out the plug in part from a vehicle like yours and leave it plugged in.
kcb14214
There is usually a sequence of buckle/unbuckle and key turns listed in the manual to turn it off.
ky2015denali
Kentucky
Seat Belt Chime
See Owners Manual Section 5-52.
5-52 Instruments and Controls
Rear Cross Traffic Alert
This allows the feature to be turned
on or off. See Assistance Systems
for Parking or Backing on
page 9-57.
Select Off or On.
Comfort and Convenience
Select the Comfort and
Convenience menu and the
following may display:
. Auto Memory Recall
. Easy Exit Options
. Chime Volume
. Reverse Tilt Mirror
. Auto Mirror Folding
. Auto Wipe in Reverse Gear
Auto Memory Recall
on or off.
Select On, Off.
Easy Exit Options
on or off.
Select On or Off.
Chime Volume
This allows the selection of the
chime volume level.
Press + or − to adjust the volume.
Reverse Tilt Mirror
When on, the driver and/or
passenger mirrors will tilt downward
when the vehicle is shifted to
R (Reverse) to improve visibility of
the ground near the rear wheels.
Select Off, On - Driver and
Passenger, On - Driver, or On -
Passenger.
Auto Mirror Folding
When on, the outside rearview
mirrors will automatically fold or
unfold when the Remote Keyless
Entry (RKE) transmitter Q or K
button is pressed and held.
Select Off or On.
When on, the rear wiper will
automatically activate when the
vehicle is shifted to R (Reverse).
Select Off or On.
Lighting
Select the Lighting menu and the
. Vehicle Locator Lights
. Exit Lighting
This feature will flash the exterior
lights when K on the Remote
Keyless Entry (RKE) transmitter is
pressed to locate the vehicle.
Select On or Off.
Exit Lighting
This allows the selection of how
long the exterior lamps stay on
when leaving the vehicle when it is
dark
ky2015denali
Undeserving
Mitch and Murray sent me.
Triad Area NC
I just added the plug in extensions. Makes it easier to reach them when I insert and release my seatbelt. Because you leave them plugged into the female side, they also make the chime think the seatbelt itself is inserted. Also works great for when hauling a dog or anything that weighs more then a few pounds up front so the chime doesnt drive you nuts.
seatbeltextenderpros DOT com $19.95. Done. :D
chevrolet-suburban-seat-belt-extender
microfoxdev
