NEW VERSION NORCAL SS'S 00-20 6" Rear Drop springs TAHOE YUKON ESCALADE
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
no you will have to get the 1 inch spacer (40 shipped) and cut in 1/2
Elrey7698
NORCAL SS'S 6" DROP SPRINGS
PAYPAL [email protected]
Springs alone $225 shipped
They will drop your 00-14 non autoride truck about 6 inches in the rear and AUTORIDE TRUCKS 5 inches in rear.
Few thing about this kit (i sell all items below)
1) you will need to run the djm hardware kit with the shorter bumpstops which is $190 shipped
2) you will need to use the belltech street performance shocks which are $130 shipped
3) You will need to cut the bumpstop bracket off the frame.
4) The springs by themselves are $225 shipped to the lower 48 states
5) Airlift helper bags fit inside also. The coil spring design I went with has no dead coils so helper bags will work perfectly and they have more of a chance to fit in between the springs. You will be able to load up truck with helper bags in the rear. Airlift 60742 is part number to work on these bags.
Yeah i have the 2200 shocks on my yukon right now. I have a djm 3/4 kit. I want the 6 inch coils but i dont want to use belltech shocks. What size calmax shock would be equivalent to the belltech shock? My ride is really bouncy
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
the designed my springs around the belltech sp shocks and no issues with ride. You will need the djm rear hardware kit with my bumpstops also to make the kit work and cut bracket off the frame. There is no way my kit will ride right without the above set up and cutting off the brackets.
Elrey7698
Can i have a model number for the shocks plz? I already did the bumpstop bracket delete on my truck. I have the rear kit also.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
you will need new bumpstops in rear which attaches to the axle in current hole or the truck will slap axle to frame
Elrey7698
I clicked on the link and it showed some black bumpstops for $15. Now which belltech shocks do i need?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
the 2410's i have those ready to roll also
Speardog
