Used the new torque app and I get
Long Term B1 10.9 (idle) 15.6 driving about 40-50mph
Long Term B2 10.2 (idle) 13.3 driving about 40-50mph
My rpms at idle RPM fluctuate 606-646 all different numbers.
I don't have any check engine lights but I still have the pinging noise (i think) between 1500-2000 rpms only under load.
I don't know much about fuel trims but from quick reading you want the numbers to be close to 0 as possible. And anything above 10 + or - when you add the long term and short term numbers is a sign of a problem.
My short term numbers are -.08 to 1.6 fluctuates. With idling fuel trim numbers I'm already out of spec.
In my research I have a lean fuel mixture so the ECM is adding more fuel.
Am i right I have an issue? The engine misses when Idling as you can tell by the fluctuating rpms 606-646.
From what I'm reading a lean fuel mixture can be caused by about 20 different things. Like I said no check engine lights either.
