Dropped Burbs & XL Pics?
magicbus
Wichita Falls, TX
Thanks guys, I really want to go lower. However, seeing it parked next to my brothers jetta, and the bumpers are even, I guess the front is low enough. I would like 2 more inches out of the back though.
It's my dd, and it drives great. I've put about 50 miles on it today without a single scrape, gone over speedbumps and dips with ease.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Just wait for my 6 inch drop spring coming out you will be happy and will give you a nice drop more. What size tires is your truck on?
magicbus
Wichita Falls, TX
It's on the factory size meow, 265/70/17. I couldn't find your thread about eliminating the rear end slop. As far as driveability, I really do love the way she rides. It's not like stock or better, but it's as good as any other lowered truck I've ever been in.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
slop thread
http://www.tahoeyukonforum.com/forum/showthread.php?t=39444
Have you measured your truck from ground to fenderlip??
With my new set up should be at around 32.5 just seeing what yours is at.
magicbus
Wichita Falls, TX
Thanks, that's exactly what I did. Only, I haven't replaced all of them yet, just the rear two on the bottom sway bar. In only doing those, I did notice a difference. I guess I will be replacing all of them sometime soon. I'm just ready to take a breather and give the mrs a break with the infant. I've been working on too many projects recently and it's time to wind down a bit.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
all good if you can measure the truck from ground to fenderlip interested on what yours is at.
magicbus
Wichita Falls, TX
Just for comparison's sake, Beelzeburb parked next to my uncle's 2wd Yukon XL (this was after a big snow so keep that in mind when noticing the offensive level of grime):
Also, next to a co-worker's Camaro:
Dammit a I need a new back bumper.
magicbus
Wichita Falls, TX
Looks good. Nice and loooooww
Thanks, I have to look at these every time I think to myself about more drop. Doesn't work. Must scrape frame. I have tried and tried (without bashing the snot out of it) to get it to bottom out or scrape on something to no avail. Says a lot for the drive-ability of a slammed burb.
mike65
