CMoore711
- Joined
- Jul 18, 2017
- Posts
- 1,206
- Reaction score
- 956
I'm trying to provide as much information as I can as to my current vehicle, what information I have been able to find so far, and what I'm trying to find out so bare with me on the long detailed post here...
My '15 Yukon Denali XL 4WD is quickly approaching 110K miles and I'd like to go through the front and rear suspension and replace/upgrade the control arms and suspension bushings.
My '15 Yukon Denali XL 4WD does have front aluminum control arms.
My K2XX Yukon Denali XL 4WD is lowered but not by much.
About 1.5" Drop Front
About 2.75" Drop Rear
Belltech 2" Drop Spindles in the front
Norcal Rear 1-4.5 Rear Adjustable Drop Kit
Adjusted Rear Auto-Ride Rod Lengths
Rear Has Free Travel Mod w/ lower profile bump stops
DJM Rear Offset Sway bar End Links
Spending some time doing some research on the line there seem to be some "beefier" aftermarket control arm options; However, all the ones I have found for the front seem to be designed for lifted or leveled trucks, I have yet to find any for stock height or lowered trucks.
For the rear control arms there is the Spohn Option for the 07-13 that do fit the K2XX SUV models. I'm partial to using the Spohn Lower Rear Control Arms with polyurethane bushings. But I don't have any experience with the Del-Sphere pivot joints that are on the Upper Rear Control Arms and fear they might be overkill for day-to-day commuting or add too much NVH. I could be completely off with that though? Then there's the rear auto-ride links; Although I'm not too keen on having to weld the rear auto-ride link attachment to the Spohn Rear Upper Control Arms if this was the only upgrade option that made sense I would consider it.
Looking at front and rear control arm part #'s on Rockauto across the different generations there are some of the same part #'s.
2006-2020 Use the same Rear Upper and Lower Control Arm Part #'s
So I was leaning towards going with OEM Rear Control Arm replacements and installing these polyurethane bushings into them in lieu of the rubber ones.
7318 | Escalade | Rear Control Arm Bushing Replacement Kit (prothanesuspensionparts.com)
There are no consistencies across the generations (2006-2020) for any of the front control arms. But I am curious if anyone can confirm if there are consistencies for the bushings and mounting hardware? Wondering if these polyurethane control arm bushings designed for 2000-2006 GMC Yukon XL 4WD would work the K2XX 4WD front control arms?
7236 | Tahoe | Front Control Arm Bushing Replacement Kit (prothanesuspensionparts.com)
My questions are:
1. Are there any aftermarket front control arms with polyurethane bushings out there designed to work with stock height K2XX 4WD SUV's that came with stock aluminum front control arms?
1A. If so, do you have any experience/feedback with them and a link to the product?
2. Are there any aftermarket rear control arms with polyurethane bushings out there designed to work with stock height K2XX 4WD SUV's that already have provisions to accommodate the auto-ride link attachment?
2A. If so, do you have any experience/feedback with them and a link to the product?
3. If you have any experience with the Spohn Rear control arms with the Del-Sphere pivot joints on your SUV on the street for day-to-day commuting? Would like to hear your feedback and input on their affects on the ride quality and NVH.
4. Has anyone successfully installed any of the above linked polyurethane control arm bushing kits into OEM front and/or rear control arms for the K2XX SUV platform?
4A. If so, please share any experience/feedback.
If anyone is aware of any other front or rear control arm upgrade options please share.
Thanks in advance for any information, input, or feedback.
My questions are:
