Kpwweb
- Joined
- Dec 11, 2015
- Posts
- 681
- Reaction score
- 286
To lift with just the bags, EdgyMods. Work great and you dial in what you want.Just got a '23 Z71 with the air ride suspension. Want to level it, at a minimum, and maybe go up as much as 2". A few questions:
What's the best lift options? I've used the air ride height rod lifters on my Land Rover but wanted to see if anyone has used these on their Tahoe and what the impact on ride quality was (https://www.suspensionsuperstore.com/2021-2023-chevy-tahoe-w-active-ride-air-ride-0-2-5-lift-kit/)
What's the largest tire you can get if you just level? Sounds like it might be around 33.5" on the OE rims? Does adding a spacer help at all with clearance/size options?
I run a 285/60r20. It seems like I get a little rubbing at full lock under certain situations, but there are no witness marks so it is good. I think the absolute largest without rubbing is a 285/70r18.
I spacer will swing a wider arc, and this have a chance to rub more on the fenderwells, especially at the rear of the front fenders.
