Replacement struts
racerx
Hello
What front struts are people using?
2012 ppv
Thanks
jz57
If you need meet PPV option, the only choice from after-market is Monroe, or go to OEM Ac-Delco.
No PPV choice in Bilstein.
kbuskill
NE. FL.
I'm running Rancho 9 way adjustable struts (RS999784) mounted under the lower control arms with Rough Country grade 9 hardware.
I like them much better than the Belltech drop shocks I had on there before.
'08 Suburban with 4/6 drop kit just for the record.
Not sure if you are looking to go lower or just keep the PPV stance.
08grey
What setting do you prefer for daily get arround
Sent from my SM-G973U1 using Tapatalk
kbuskill
NE. FL.
I rode with them on 7 for a long time. I recently turned them up to 9.
I prefer a firmer ride, that is why I didn't care for the Belltech drop struts too much.
jz57
From the pix you posted, the strut bottom bracket was installed under the front lower control arm, it should be installed above the front lower control arm according OEM setup.
