Long and low
992dr
N.C.
I figured out why the back of my truck was riding like dog shit. The trailing arm bracket bolt pulled through the washer so the whole bracket was just loose. I welded the trailing arm bracket and shock extension brackets right to the rear end and now the truck rides like a dream
Hmm, interested in seeing this. Could you snap a couple of pictures of where you welded them?
Had to take the opportunity View attachment 220729
Lookin goooooooooooooooooood
Doug118
Doug118
The truck never goes up in a lift and I’m definitely not fitting underneath lol. I just welded the brackets anywhere they came in contact with the rear end
Doug118
Doug118
Forgot I sent @Leo1103 a picture when I did it. Yeah it’s the DJM stuff. After speaking to a bunch of people, I regret doing drop shocks and shock extensions. You’re supposed to do one or the other, not both
And the drop shocks that go with the kit are a horrible combo with the 6” drop spring.
992dr
N.C.
Cool, Thanks.
One or the other, not both? Huh, that's a first.
I thought without the extender the angle of the shock would be almost 45 degrees (that's and exaggeration) but it would be at an angle where the shock would not perform as it should being more upright.
I need to get under mine, its about that time to re-tighten everything, again.
I may end up pulling my welder out and just zap everything.
992dr
N.C.
Lookin good man.
Any plans for new rear arms?
Doug118
Doug118
Lookin good man.
unfortunately I screwed myself with that. I already notched the frame and didn’t anticipate the weight in the rear making it that much lower. So if I do arms to center the rear, it won’t be centered in the notch
Whale, shit.
APalmer15
