Engine flush
K9Gunner
I am at 276k miles on my 2005 Yukon 5.3. Wanting to do an engine flush. I have LiquiMolli and Amsoil engine flush. Which one should I use?
ks03
Fool Excess Member
I’ve always been skeerd of engine flushes. I prefer the idea of reduced interval oil changes, which should eventually get you to the same point.
K9Gunner
K9Gunner
I do 3k already.
afpj
What kind of issues are you having that makes you consider a flush?
K9Gunner
K9Gunner
Having some lifter noise
JonnyTahoe
Minneapolis
What are you waiting for. Your bought the stuff so why not use it and see if it fixes the lifter. Which one.. flip a coin.
dougo
Raleigh
My thought use Marvel Mystery oil as an additive it helped quiet mine , also make sure you don`t have a loose spark plug sounds just like a lifter. I have flushed mine at 150 to clean the out of the pan
A lot of times on an LS, what sounds like lifter noise is actually an exhaust leak from broken exhaust manifold bolts which these engines are notorious for. I would check those first.
fpuvak
