Missing OBD pins
Multnomah Falls
Military
If they got the wrong connector the rest of the pins may be there and wires spliced and you could get the right connector and then wire that one in?
T
TeaSpoon
Yeah I checked behind the connector and the wires are all taped up right to the plug, none are missing out of the plug or falling out. Not sure if from the factory they taped them up for that short 3” run from the main harness, it thinking they’re in there somewhere and never got plugged back in because someone didn’t know where they went on a rewire
T
TeaSpoon
I’m thinking I need to unwrap those wires and pull the cover off the main harness and see if they’re wrapped in somewhere. If I could figure out where the CCM and SIR lines originate I can trace them that way too.
Multnomah Falls
Military
Good call. Gotta go exploring. If you know for sure the other connector was in there to begin with then the wires have to be there, IMO.
T
TeaSpoon
That’s what I’m really trying to get to the bottom of. I don’t know if they were there originally, but I have yet to see or hear of a truck of that series with the #8 pin missing
Multnomah Falls
Military
That could be #8 missing if the truck was originally made with the connector in my #9 post.
T
TeaSpoon
I found that layout, That’s a 2002 and newer layout for the switch from VPW to CAN
Multnomah Falls
Military
Yea, where I found it, it was not clearly marked. Sounds like you have some exploring to do. Oh joy! :(
Leno1364
