New iPhone, new Apple Carplay issues
jeffbco
If you go to the Beta version of iOS, this appears to be resolved. I had this until I went to the beta and haven’t had it happen since.
2016 Yukon Denali.
I'm running iOS 13.2 Public Beta - no issues.
GTNator
GTNator
So should I wait for the next iOS software update or ask GM for an update?
jeffbco
As I mentioned, it runs fine on 2019 Yukon Denali using both iPhone 7 and X-r running iOS 13.1.3 so I doubt it’s the iOS and GM isn’t going to have any update. I’d keep trying reboot everything, etc. good luck.
camaroz2887
Nj
Have ya tried a new cable? I just went thru similar issues with CarPlay and it ended up being a combination of an old lightning charger and a charging port packed full of idk what.
If the phone is more than a few months old take a look in the charging port. I dug a lot more crap outta there than I thought was possible. Just be careful what ya use don’t wanna hurt the phone as expensive as they are these days.
jeffbco
Not only just a new cable but sometimes it may need to be a Apple cable.
camaroz2887
Nj
What Jeff said. They do have “mfi” certified cables whatever the acronym may mean it’s a productApple certified, just cheaper.
GTNator
GTNator
I agree, Apple is touchy about the cable, their own branded ones work better from a compatibility perspective. But the after market ones are sometimes more durable.
I actually have tried both cables, Apple branded and non to the same result. Ordered a new Apple cable just in case and will try that one too.
GTNator
GTNator
Thanks for the advice, I’ve done all that so many times. Just FYI, even though you’re running iOS 13.1.3 on an iPhone 7, it’s not going to be the exact same code of iOS 13.1.3 that is running on an 11 Max Pro. They’re all slightly different, not a lot, but sometimes just enough to make a difference. Maybe the version they use for iPhone 7’s works flawlessly with CarPlay.
cardude2000
Now 90% of the time the vehicle doesn’t even startup CarPlay after I connect my phone. And as I said I know there’s a connection because it’s charging. So the vehicles display will show whatever was in there before and no CarPlay icon appears. My phone will have either google maps or Waze on its screen.
Try a different iPhone cable. Sometimes the knockoff ones will work for a while and then get fussy.
My 11 Pro works fine with my 2016 yukon
jerry455
