Dreaded Rust..
Sdp1234
Southeastern PA
I was washing the White 2004 Denali today and noticed rust behind the back passenger side step
Is there a way to remove the plastic and do a diy repair?0CDC54E9-F987-4567-AFF8-B10A64C30516.jpeg 1315B71D-927D-4FF0-B101-04F93B9FFC83.jpeg
S
Sdp1234
Southeastern PA
Fender flares are held on by a mix of push clips in the fender and molding tape
Thanks what about the side step? What is the best way to repair the rusted metal under the flare and step. I just want to slow the rusting process
TysonTrost
St. Louis
preparing to use fiberglass mating and Bondo to do the whole quarter panel. if you don't want any repair i guess put a silicone rust preventer on. It really only took 2 years for this rust to grow like cancer
massivespl
I'm not mean, I'm honest.
Michigan
Rust is called cancer for a reason. Even if u cut it out and weld a new piece in and paint in acouple years the rust will be back. That’s why no one will ever warranty rust work.
S
Sdp1234
Southeastern PA
Thanks guys. I don’t understand he cancer thing. How can it come back if it is completely cut out? If that’s the case is it even worth it to try to fix it?
If I cut the damage out and weld or bondo will it at least slow the progression? Is there any paint rust converter or process that slows it down?
Is there a difference between surface rust, rust and cancer rust?
Is here a web site that explains the science behind this? I would love to understand.
I want to fix it but slowing it down will help.
S
Sdp1234
Southeastern PA
removed the side step. Rockers are good surprisingly. Getting ready to grind and repair the front of rear quarter panel. Suggestions on how to do this easily? Most everything is covered with Denali trim. Planned to grind out and bondo/fiberglass
CF9FDC63-D8FC-416A-B9C6-3C439AD3C16E.jpeg 9186BC4C-637E-4451-985C-9E3CA8C449E4.jpeg
S
Sdp1234
Southeastern PA
Should I purchase a font lower quarter panel, cut it down and panel bond or weld? May be able to put the seam behind the Denali trim. Has anyone done this?
wjburken
Eastern Iowa
It all depends on how deep you want to go.
The Denali trim is not helping as crap and moisture gets in behind it and can sit and start to attack the metal.
Also, many times the rust you are seeing started on the back side of the panel and is finally poking its ugly head through on the front side so sanding and covering the visible side is simply a temporary band-aid.
Multnomah Falls
Military
I lived in KC, Mo for over 35 years and dealt with rust all the time at my shops. Hated that "cancer". Moved to Oregon 23 years ago and they do not use salt on the roads here. Rust problem is gone. So, decide on which is cheaper, moving or fixing.
Chevelle ss
