Fog lights upgrade?
chevync
North Carolina
I just noticed one of my fog light lense is missing, do they make a different style housing? Most I find are cheap made. 2003 Escalade.
I think they're all pretty much the same. Oem or aftermarket. I took mine out and rrplaced them with led fogs.
I ended up going with some like these, they fit in a rectangular slot and can be wired up to the factory harness, water tight.
just had to use the factory light bracket and make a hole in it for the bolt.
https://www.ebay.com/itm/2pcs-Cree-7inch-Spot-Beam-Led-Light-Bar-288W-Fog-Driving-Lights-Offroad-Tri-Row/183581081177?fits=Year:2012&epid=27024751508&hash=item2abe48fe59:g:5FoAAOSwhspb6VYq:rk:116:pf:0
Nice. I see they're made by Cree. How long have they been on? Did they get moisture inside of them yet?
The one's I originally bought were 2 row but these are basically the same thing I had 2 set's on my NBS for a couple years before i sold it and they never got any moisture in them and they worked perfect I sold it almost 2 years ago and I last saw it about 6 months ago and there were still running nice and bright I had one set setup as DRL and I don't think the new owner changed anything. my ex has a set on here 04 suburban and they still work and never have got any moisture in them. the oem fog lights are a poor design they wouldn't go 6 months without being 1/2 full of blinker fluid and burning the bulb out because of it.
these ones are a closer match to what I originally purchased, the ones above are probably just a newer design, either way they are super bright even in daylight you cant look into them for more than a second without being blinded, lol
https://www.ebay.com/itm/2x-7INCH-3...=item3d388e56f3:g:IyYAAOSw-0xYQrnQ:rk:47:pf:0
the round ones I bought for the nnbs last year have gone up a $100 and are currently sold out.
I should've gotten some Crees.
first thing I tried for a while was some sealed projectors but those were basically a joke, I was skeptical about getting the led's because the ones I had used before as DRL's and the ones that are like a strip in the lower turn signal housing all didn't put out much light at all so I was pleasantly surprised when I tried one out of the box with a power tool battery I was like holy crap! then I thought for sure they would take a dump soon but they held up, even survived a couple fender benders without a scratch, only thing that happened was the plastic oem fog light brackets snapped off so I just bought some cheap $20 oem type fog lights and tossed them and used the brackets they came with to re-mount the led's
03YukonNH
Manchester, NH
I did the same as mentioned above. These are the ones I got:
I also got those H11 pigtails so the LED wiring could match up with the factory plug. Only gripe is the paint has chipped over time
Chuckchill
