Cutting out the spare?
Its the rod with the hook like end correct? Kinda makes like a [ shape? I've gotten it to catch on something before, but when trying to turn it, it just slips.
Wrong end like others have said. Use the square end. The hook like end is just for the jack. Hope you got it figured out by now?
HiHoeSilver
Away!
Chicago
That was the only way I was able to drop that damn spare!
I just fought with mine when I did the fuel pump a couple weeks ago. I was able to reach up there with a big screwdriver and push that stupid latch enough to make it let go... Dumbest. Design. Ever.
mattt
If you're not sure which end to use, look in your manual or look on the plastic instruction sheet that is sewn into the bag that holds the tools. Both places show which tool and which end to use.
Martinjmpr
Littleton, Co
F*ck you, you secondary latch!!!
No kidding. As I said, my solution was the grinder. Then once I got the tire down I removed the whole spare tire hoist and cast it into the fiery pits of HELL from whence it came. :flamingdevil::flamingdevil::flame:
The good news was that I was able to get a replacement that was completely identical to the stock unit - MINUS the awful secondary latch. So after several months of driving around with the spare tire in the back, I was finally able to put it back under the truck.
Toomanyhobbies
If you have to take out the winch (which you will since there are probably around 6 million GM trucks on the road with spares that won't come down) do what these guys said above and cut the whole thing out. I spent 4 hours trying to make the secondary latch close based on youtube videos and I couldn't get it. I have a 37" arm and tried to go behind the license plate.
boromircalantir
