A little something..
Unit171
NC
I tied into those same wires. I used the top connector at the factory amp. Followed the wiring schematic that’s posted on the main forum. Used posi-taps too.
Pissing me off is what it is doing very well. I’m about to pull this amp and speaker and try it in my 2007 Tahoe just to verify the amp isn’t the issue
Unit171
NC
Can you take a picture of your LOC tie in? Maybe my loc is ******. I can upgrade to the audio control but never have used them
Usdmskyline20
Usdmskyline20
I can. Won’t be until the weekend.
2011 Dodge Ram 1500 Big Horn
2017 Chevy Tahoe LT
Unit171
NC
Thanks. I just tried installing an LC2i.....didn’t change anything. I even went in and cut the ANC Mic signal wire to the amp. No change.... killing me
Usdmskyline20
Usdmskyline20
Thanks. I just tried installing an LC2i.....didn’t change anything. I even went in and cut the ANC Mic signal wire to the amp. No change.... killing me[
I’m sure you probably already done this but check and make sure your ground is solid. Check your rca at the LOC and in the amp.
2017 Chevy Tahoe LT
DarkHearse
