Running 1/0 gauge power wire
KilluminatiDre
OK how would you guys suggest running 1/0 gauge power wire from the front to back of a 08 Tahoe. It definitely doesn't seem like the side floor panels are deep enough, which is what I usually do. Also I have a SSV so I don't have carpet.
Also does anyone know of a basic wiring harness for head units that doesn't come with the "door chime speaker"?
I would go underneath the body, along the frame, until you get to the back and then go through the floor back there. There's runs of other wiring or even hvac lines going back there if you have rear heat/AC.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
This is what I did...
I went from the battery down the frame and came up on the driverside rear...
You can see my ground and the power going through
K
KilluminatiDre
Thanks for the replies guys. Would I need to drill any holes or are there pre-existing ones that I can use?
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Need to drill
massivespl
I'm not mean, I'm honest.
Michigan
There's a factory hole in fire wall under the steering wheel that has like a rubber boot on it that other wires go through. I ran my wire through that and under the carpet to the back. I don't like wire under the vehicle, all it takes is some road debris to hit the wire and split the jacket and could potentially start a fire
Isn't that what fuses are for?
Meccanoble
Georgia
Regarding "chime", this is typically added with wiring harness setups that come seperate from HU. I know my PAC wiring came with the "chime". I had the option to install it and make it as loud as I wanted.
TLTFAB
4 gauge or smaller I run it under the carpet, 0/1 gauge I loom it and run it along the frame rail. Much easier to route.
2011SSVHOE
I'm an egual oportunity offender
The Heart of The Triad, North Carolina
You have an SSV you should already have a good size 12volt feed to the rear. Just look inside your jack compartment. Just my 2cents
MrRuiz
