Kenny D's Tahoe To Go thread
Kenny D
Crosby, Tx
I am basically going to start this thread as a way to keep track of maintenance and mods for my 09 Tahoe.
Join in with your honest opinions if you like, give advice is you want, and steal any ideas if you need to.
For starters, I purchased it Feb 1, 2017 with 130247 miles.
11 days later I did removed the door trim that was curling.
Before:
After:
March 1st I replaced the following:
ABS sensor AC DELCO 20938122 for passenger rear wheel.
Passenger side mirror glass DORMAN 56082 .
Front swaybar links AC DELCO 45G0002.
Brake switch AC DELCO D1539J
Ordered all those from Rock Auto .
March 6th, I installed a Diablosport I2013 tune.
http://www.ebay.com/itm/381432232470?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
March 25th, I did a complete brake job.
Then you guys gave me some more inspiration.
Today I installed my LED reverse lights and underhood LED lights.
This is the stuff on the agenda today.
http://www.ebay.com/itm/251554320246?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
http://www.ebay.com/itm/291161780706?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
http://www.ebay.com/itm/251370472630?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Kenny D
Kenny D
Crosby, Tx
The under hood light install went easy. I started by locating my switch. I used tin foil to set switch height. 20170414_165121.jpg
Then I closed the hood and measured the height.
Then removed brace and installed switch.
Then I built my wiring harness. I tapped the power from the junction box by the battery.
Kenny D
Kenny D
Crosby, Tx
I couldn't get good pics of the reverse lights, but that install was pretty easy. Probably will add 2 more LED strips under the hood at a later time.
Kenny D
Kenny D
Crosby, Tx
How do you guys get the build sheets to show up as an image. Mine came as a PDF
juniordaboi909
