Is there an easy way to get my cluster to light up again?
Jay R Lawson
cluster and other lights are going out. Would like to upgrade to led. Is there a simple way to do it?
Fosscore
Alternative if you don't want to do it yourself is to send it out. There are couple places mentioned on the forum.
One comes to mind Digital Dash Solutions. They can do LEDs, quick turn around time, new stepper motors as needed and even a trans gauge if you don't have one.
Just something to consider.
BigDaddy13440
Rome, NY
rockola1971
Indiana (formerly IL)
And just FYI, your vehicle WILL run and drive fine without the cluster installed. You just wont have any MPH indication or coolant temp, oil pressure notification, etc.
mattbta
Frisco, TX
But will you lose miles while the cluster is out if you drive it?
BigDaddy13440
Rome, NY
I can't say for sure, I don't know if the memory is in the cluster, or in the PCM. Maybe someone that has swapped a good cluster in for a bad one would know.
Xay2Smoove
