305 50 20?
Chris73838
Hey guys I'm installing 2.5in keys and 1.5in rear spacers on my 05 Tahoe LS 4x4 I'm also wanting to order wheels and tires. The wheels I'm thinking about are 20x9 with 0 offset, my question is can I run 305 50 20 Terra grapplers? Supposed to be 32in tall so I assume they will work, any thoughts?
C
Chris73838
Ok cool. Do you think that size is a good choice? They also make a 295 55 20 which is a hair narrower and a bit taller idk I'm kind of leaning towards the 305s because there a little cheaper
osiris94ej
Casper Wyoming
There is also 275/60-20(33x11)
20x9 0 offset with 275/60 Falken AT3w. Just front level. Stock rear. Got my tires at just under $700 for the set. Wish I would have went 295/55 or 33x12.5 now though. I have more than enough room as it sits.
Sent from my SM-N920V using Tapatalk
C
Chris73838
Looks nice, do you like the 0 offset wheels? Your bottom pic looks like you have fender flares but the top one doesn't. I just bought my hoe and it has flares but it's missing the pieces that go on the rear doors looks kinda weird thinking about removing them all together hoping the paint isn't messed up under them
osiris94ej
Casper Wyoming
It has flares. 0 offset on a x9" wheel is just at flush with flares.
This is coming from the previous 18x10's -24 offset, with a 32" tire.
All the same suspension heights.
C
Chris73838
Do you think the tires would stick out too far without the fender flares? As u can see I'm missing part of mine and don't know if I can buy just the pieces I need.
C
Chris73838
Well the shop installed the keys and 1.5in coil spacers and he said even with the keys adjusted all the way down it was like 1.5in low in the rear so I guess I'll roll with cranked stock keys until I can figure something out. I can't believe it was that much off it all came as a kit Bilsteins and all, would Z71 springs even be enough? Mayb my coils are wore out?? I'll see what it look like tomorrow with cranked stock keys but pretty disappointed honestly.
Pepper1700
