Won't start, replaced fuel pump, still won't, Code P1626 - new owner with dead truck
YukonandtheHOE
One other question then- can a tuner remove it or disable it? I have an Autocal from BBP.
I never really played with EFI Live on gassers, but im sure their would be a VATS patch in their you could apply, HPTuners does.
E
EscaHoe
My buddy has HPtuners and said if you hook it up, without buying any licenses, you could check using the Test mode to see if turning off the VATS would work. But as soon as you unplug the computer, it will not start up anymore. You must buy the licenses ($100) to unlock the VIN to fully turn it off. I've heard this doesn't always work though.
If you're have the same problem as I did, go to Radioshack and get a handful of resistors. It won't cost anymore than $10. Then splice it in. I had a yellow and an orange with black stripe (not the solid black).
YukonandtheHOE
Unfortunately, you have to License the ECM before you can Apply any changes or patches. 2 credits at 50$ a credit yup.
Comes with a pretty fun scanner tho! You can go into tcm and ecm and do allsorts of diag
E
EscaHoe
Totally. It's worth it, but not a priority for me right now. I'd like to mess with the shift points and stuff. My first to second is a little rough.
As far as $100 for HPtuners licenses to fix the passlock issue, i'd recommend the resistor method all day every day. So happy that worked.
rockola1971
Indiana (formerly IL)
I tried to check that but could not locate it. Another post alluded to it being connected with the radio fuse. Pulled it and it was fine. Even tried to start it when it was out; wouldn't start.
I may have to suck it up and leave it to the dealership. It's $140 to use their Tech 2 scanner.
Or you can get your own ****** tech 2 for $240 and do whatever you want, whenever you want.
Like I said, I have a Autocal from Black Bear Performance, with a license for my VIN. It comes with lifetime tuning and I can have any changes I want or a completely new tune emailed to me any time. It only takes a few minutes to install once I transfer the files to my Autocal. So I was thinking if I ever have trouble with VATS I can have them email me a new file to disable it.
YukonandtheHOE
Dont you have a ECM editor with autocal? That you can manually in a tweak settings with?
Not sure. The software is confusing to me, and I don't want to mess shit up. I paid for lifetime tuning so if I want something done, I'll just ask Justin to do it for me. It's better that way! I'd probably end up bricking my ECM.
Jandy
