NEW VERSION NORCAL SS'S 00-20 6" Rear Drop springs TAHOE YUKON ESCALADE
Hammered Avy
the 2410's i have those ready to roll also
Tony I want to buy your NORCAL SS CUSTOM 07+ 5-6 Rear Kit, minus rear DJM hardware my truck is lowered & have the DJM hardware already on it & have done the free travel mod as well. Can I get a price (pm) plz.
16blkltz
I have a 2016 Tahoe LTZ (with autoride) with a 2/4 (3.5) drop installed and on 24" wheels. The rear still sits approx. 1-1.25" higher.
Will this 6" drop spring (5" for autoride) be enough to make the front and rear fender spacing equal?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
What rear kit are you using?
16blkltz
Originally purchased and installed 2/3 kit (Front spindles/Rear springs with shock extenders) from mcgaughys, but later replaced rear springs with Belltech's 4" drop springs (3.5" for autoride).
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Are they the 5305 coils?
Did you use the spacer?
Did you cut bracket off frame?
Did you do my endlink/bumpstop kot?
Are you using extenders?
16blkltz
- Belltech coil spring kit 34324. According to parts list, they are 5305-001 springs.
- Did not use spacer (I know this will only increase the height of rear).
- Did not cut off bracket from frame. I'm using Belltech bumpstop that came with kit (shorter than stock). I don't want to cut off bracket. There is approx. 1" gap between Belltech bumpstop and bracket on axle. I did a road trip with 4 other adults and completely filled remaining space with gear (up to the ceiling), and the ride was awesome. The autoride did it's job well. I would be willing to cut Belltech stop shorter if necessary.
- Did not buy your endlink/bumpstop kit. Will there be huge difference in ride performance?
- Using extenders.
16blkltz
Took this shot about a month ago. Not the greatest, but at least you can see the annoying gap difference between front and rear.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
1) remove upper spring insulator and the the 5\8 heater hose mod I've been doing on them
2) my autoride links to get it to sit lower
3) you will need to cut bracket off frame to get a decent ride if going lower.
4) my endlink kit will fix the away bar angle for better ride and cornering and will need my bumps top if cutting off bracket
Attached one done recently. My custom 2/4.5 kit
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
My escalade with my custom 3/6 kit
295 30 26
32 7/8 front ground to fender lip front
33 3/16 ground to fender lip rear
justjacks07
