[SOLVED] Fast blinking after Turn Signal LED bulb swap
Tom Joad
French V8 lover.
Chamonix-Mont Blanc ski resort,. France
Hi guys..
I've boughts LED bulbs for my turn signal/hazard few weeks ago.
When I replace even only 2 out of 4 bulbs I noticed that the turn signal was really fast though the hazard signal was still at normal speed.
To fix this I only had to replace the OEM thermal flasher which is set under the dash panel, with a Novita LM487 enectronic flasher.
I did the swap today and I tell you this works without adding any resistor : both hazard AND turn signal blinks at a normal rate.
https://www.amazon.com/Novita-LM487...hoe&keywords=2003+chevroelt+tahoe+led+flasher
05Single
afraid of the dark
I need to get this and throw away my ugly resistors
OhFourChevy
Houston Tx
It's a really simple install, pull your old flasher from behind the kick panel under your steering wheel, easiest way to find it, is turn on your hazards, and it'll be a large relay that buzzes when your hazards click.
Simple pull and replace, the factory one is in there pretty good, just FYI, takes a bit of pulling to get it out
05Single
afraid of the dark
Yea I was reading and someone said it was a pita to replace. I couldn't imagine it being too hard.
Tom Joad
Tom Joad
French V8 lover.
Yes, really simple.
I'll post pics this evening.
Remove the panel in front of your knees, you'll see a metal part. Behind it you'll see the OEM flasher, pull itwith a light move fron front to back then replace the LM487 there. Enjoy.
05Single
afraid of the dark
Oh haha its literally right there. Eazy peezy
rick9667
