Turndown sound on tahoe/yukon?
mdestb3st
hey guys i was wondering how a turndown exhaust (or 2) would sound on a tahoe or yukon
correct me if im wrong
but a turndown (from what i have learned) is when you cut the exhaust pipe in half so it goes headers, shorter pipe, muffler, then a couple inches of pipe facing the ground
there might be a diffrent name for it but its just the name all my friends use when talkin about it
it sounds pretty good on trucks, just wondering how it would sound on a tahoe/yukon
thanks,
Modded
That Guy
Yeah thats what it is, also known as dumped.
It sounds good but you may have to worry about fumes getting in the cab, **** on the undercarriage, and excesssive interior noise.
Can't forget that it is also easier for water to get in the system...
blueflamed03
Oklahoma
most lowered trucks, SUV's and you can't see the pipe is dumped. I have a 50 series Flowmaster on mine dumped right after the muffler. Sounds great. Look around when driving, and if you see a truck,etc with no tail pipe, I bet it's dumped. makes for a nice, deep rumble.
PS welcome to the site!
M
mdestb3st
haha thanks bro, ya'll sound nice around here lol
and i seee but how much do you think it would be around to get two, if possible?
nd i think the fumes can get in the cab if the pipe is too short
but im not positive on that one
blueflamed03
Oklahoma
it can, but as long as these are computer controlled, and you have cats, it's not noticeable at all. If you already have the muffler, usually muffler shops will charge like $20-$30 to add turndowns.
Modded
That Guy
No matterwhat, doing two of those won't be as expensive as doing duals all the way to teh back. I would say just makesre the pipe is actaully turn down where it ends.
SHould run probably around $200 with a muffler (single in/dual out) and install.
Also duals is more of visual thing, if your dumping keep it single....
M
mdestb3st
wait computer controlled?
what if you had the shop make you a muffler and everything
like my friend got a turndown on his silverado and the shop took out the entire exhuast (besides headers) and they made the muffler and everything for him...it cost him around 100
it sounds great though
is that completely different from what you were thinking?
---------- Post added at 03:27 PM ---------- Previous post was at 03:26 PM ----------
and i wanted to put 2 for more noise, do you know if it would sound worse with 2?
blueflamed03
Oklahoma
computer controlled, like non carbureted :D
you can find a decent muffler, Flowmaster, or a Turbo muffler, and have a turndown right after the muffler. Look at mufflers at Advanced, Pep Boys, etc...
craw under your truck, and see if your muffler is center in/center out, or offset in/offset out,etc.
see how the factory pipe goes IN, no worries on out if you plan to dump it.
it would be louder with two.
M
mdestb3st
i seeee, well thanks alot for the info guys! really appreciate it!
M
mdestb3st
sure will!...might be a while considerin i gotta save up but i will! haha
Nickleahy23
Portage/Menomonie, WI
you could do it yourself..just cut the pipe off right before your stock muffler. go to the auto store and get a 3" adapter to whatever size the **** is (probably get 2.5" in/out. you can also rent a tailpipe expander from the auto store. stock pipe is 2.75" before the muffler. expand it a little bit to fit the adapter, then clamp that on. then clamp the adapter to the muffler, get some strapping to support the muffler, then buy a turndown and clamp it on to the muffler..should be less then 100 with the cost of the muffler
ROBERTOcritser
Kentucky
dude dont even worry about mufflers. just find you a muffler shop to cut out the muffler then run a piece of pipe until right after the axle then dump it there. Mine is just muffler cut out with a pipe welded in the gap and I love it.
1highbaldguy
So Cal
i just got the 50 series flowmaster and sounds pretty good dumped. has a nice deep rumble. i paid 200 installed for the muffler, turndown, and install.
edit - mine is dumped right after the muffler, before the axle.
blueflamed03
Oklahoma
that's my exact setup as well :)
Max
Mile High
Denver
I love mine especially with the longtubes. Quiet on the highway with no drone, loud as hell when I want it to be
Nickleahy23
max you runnin a turndown? im thinin of cuttin mine off right before the pipe turns to come out the side..im sick of the stock exhaust stickin out like a sore thumb
Max
Mile High
Denver
Yep I hated the tip even on the magnaflow it was a pain in the ass to keep clean
WITCH1975
