3 inch lift on 99 hoe
99COOP
Retired
Chicago, IL
sway bar end links, and new shocks, both of these can be done without but will ride ******, and will over extend your shocks. and what are you doing for the front ?
Saodrin
Saodrin
Pennsylvania
i was thinking about cranking the torsion bars and possibly ford keys but idk. what else could i do for the front for cheap
99COOP
Retired
Chicago, IL
keys would be fine, the other route is a 2-3 inch lift which replaces upper arms and drops the diff. down. other then that and your looking at a full lift which just about triples the cost.
99COOP
Retired
Chicago, IL
RCX makes one for about 350-400 i believe and skyjacker makes one for like 500 i think, maybe less. There are some others out there, however theres a member on the board (happyspaz) who has one you could ask him how he likes it.
992door
Greenville, NC
I know this is a little late but hapyspaz has the skyjacker 2-2.5 and this is what he tole me about it
hapyspaz said:
Im loving it. Once I reinstalled the front diff bracket backwards from what the instructions state, the ride is awesome. Every Skyjacker lift I have ever used has always been amazing. The angle on my axles is basically factory with the torsion bars cranked almost all the way.
Saodrin
Saodrin
Pennsylvania
yea i wonder how much that 2 - 2.5 lift would be i only need the stuff for up front i dont car if the fronts a bit lower i just need to be able to fit 33s
JamesinAbilene
