Twin Fuel Pumps?
95TwinTT
Minnesota
Anyone here using multiple fuel pumps. If so, what brand and model fuel pumps and what size lines are you using from the tank? Also curious about the brand and model of regulator and if the hook up is parallel or serial?:cool:
AtomicHoe094
Atomichoe094
cleveland, OH
really twin?? lol no one on here has that BADASS of a setup as you and no where near the horsepower your kicking out. or should i said YET! hahaha.
But i havent even heard of anything like that on these little forums.
We usually learn from you lol!
Whippled2dr
Stock
SF Bay Area
You'll probably find a lot more info about fuel pumps over on performancetrucks.net. I've seen a couple of nice setups over there.
95TwinTT
95TwinTT
Minnesota
Thanks for the tip. There seem to be several guys over there with dual pumps.
My 300 lph Bosch is not keeping up at high rpm’s. I need another pump before I turn the boost up. Not sure if they have to be matched pumps or not. My plan is to turn on the second pump, starting at 8 lbs of boost. :cool:
foreverfalcon40
In my dsm I was running twin pumps. One in the tank and one inline. They were not matching pumps.
95TwinTT
95TwinTT
Minnesota
I need to run two pumps in parallel from two separate feeds coming from the tank. The one fuel line is not enough to satisfy the demand at high rpm’s. :)
WITCH1975
