Brake lights not working
rdhenderson
Bellingham, WA
My Brake lights do not seem to be working. All of the other rear lights work and the fuses all seem to be in good shape. Any thoughts on what to do next?
retorq
Kingman AZ
The bulbs are ok?? My 95 had blown the drivers side tail panel twice. The first time I noticed the guy hacked up the wiring and one was loose, so I fixed it. When it blew the second time I go new LED lights and totally removed the hack job that was there.
Do you get any lights back there at all?? If I recall all the bulbs were the same dual filliment bulbs, swap them around and see if you can track down exactly what circuits aren't working ... you may be in for some new panels or lights.
These are the ones I ended up with:
http://cgi.ebay.com/ebaymotors/1992...r_Truck_Parts_Accessories?hash=item414e245b32
99Yukon_Z71
Crazy Puerto Rican
Humble, TX
First off you did the right thing, check all fuses. If the hazards and turnsignals are also dead, then it WILL be the fuse. Check wiring, sockets(circuit boards) for any rust or contamination and also the brake on/off switch at the pedal. If your cruise control wont disengage by applying the brake, theres your dilemma. Hope this helps!
R
rdhenderson
Bellingham, WA
I pulled the left tail light off and checked the bulbs and they all appear to be good. Based on the fact that both brake lights as well as the third brake light is not working I do not believe it is the bulb. Hard to check the wiring because it is all routed up in the panels and tucked in beind the receiver hitch. I'll give the Cruise control test a shot and see if that is it.
riviera rider
brake light switch under the dash drivers side, cheap fix kind of a pain in the ass to do, dont brake the clips when u take it off!!!
that IS your problem i gaurantee it, same thing happend to mine last summer when i first got the truck
its a little pressure switch when u push the pedal it pushes in the button and sends power to the lights
lemme know when u fix it! :)
R
rdhenderson
Bellingham, WA
Where did you buy the replacement part? and how much was it?
riviera rider
autozone or advance auto parts, less than 20$ if i recall, i know it was pretty cheap takes about 30/45 minutes to install cuz its a pain to get to just make sure u dont break the clips cuz i think you can only get them from the dealer lol
R
rdhenderson
Bellingham, WA
What a pain in the a** to get off. However, I believe you were right about it being the switch. When I opened the door I heard a clicking sound from under the dash that went away when ever I pushed on the brake pedal. I was able to find replacement parts, and clips, from RockAuto.com. One thing I did notice is that when the switch was removed none of the other electronics seemed to work? Maybe it is a safety item?
riviera rider
well ididnt mess around with anything else while the switch was removed, but im 99% positive thats your problem
R
rdhenderson
Bellingham, WA
Riviera Rider was right. I received my new switch in the mail along with some new clips last night. hooked it up and now the lights are working. $20 in parts and about an hour of time.
lordgorlok
no brake lights
I had an issue with my brake lights on my 96 yukon slt. My brake lights and all turn signals wouldn't work occasionally. I found out that the chmsl (center high mount stop light), still worked, along with the running lights. When I tried the hazard lights, they didn't work either. But when I jiggled the flasher relay back and forth, it would click, and all the lights would work. I checked the brake switch, the turn signal stalk, and all fuses, and then finally bought a flasher relay from auto zone. Problem solved. It turns out that because the rear turn signal, hazard, and brake lights all use the same filament in the same bulb, all the power goes through the flasher relay. $12.99.
DjWooPig
so i just replaced my brake light switch, and still dont have any brake lights, however when i trigger my trailer brake switch, the brake lights work. Im thinking its the flasher relay. Where is it located? I have a relay spot for the brake lights under the hood, but it doesnt have contacts.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
dj when applying brake the flasher is not used and bypassed. it is important to find out where the trailer brake controller output is spliced into to so i can pinpoint here the break is at. in the meantime check both stop/hz and turn/b-u light fuses and activate and deactivate your hazards using the switch on the column and try the brakes again.
---------- Post added at 04:55 PM ---------- Previous post was at 04:54 PM ----------
also provide your vehicle year please.
DjWooPig
Sorry, vehicle is 1999 GMC Yukon 4WD
Pulled and checked fuses under the hood. Unless there is another fuse block somewhere all where good. Activated hazards on column with no luck. Also i now have no hazard signals as well. I have park lights, head lights, turn signals, and reverse. No hazards or stop. There is a spot for a stop light relay on under hood fuse block but as i said earlier there are no contacts for a relay. trailer wiring is no hack job as i did it myself with proper tools and fittings. Trailer brake is spliced underneath dash into the stoplight (white) wire. Also noted that i am not getting any output current from brake pedal in my tekonsha menu settings.
SunlitComet
OBS Jedi-Do Good
yeah open your driver door and you will find an access cover on the side of dash panel. you will find a mash of fuses in there labelled #1 stop/haz. that empty rely socket is provisioned on non-suv models.i think you just popped that fuse is all.
DjWooPig
wow im an idiot. Ive had this truck for 5 years and forgot that panel was even there. Will check in the morning. You are probably right.
DjWooPig
yep blown fuse. Might not have even needed to spend an hour with my big ass flopping around in the floor board replacing the BLS. Oh well its one less thing to worry about!
tarh33l
I have a 97 tahoe 4x4.
I curently have no "rear" "lower" break lights, or turn signals.
These are the only lights that do not work.
Front head lights, turn signals, running lights, and hazards all work.
Rear third break light, running lights, and reverse lights all work.
I have no rear hazards, turn signals, or break lights of course, because they are all the same light.
I have checked all fuses under the hood, and inside the vehicle, and they are all good.
The break light switch by the pedal seems to be working, since the third break light is still working, and makes the desired clicking noise. I could be wrong, but I am assuming this switch controls all three. The hazard switch, or relay seems to be working since the font hazards work. No clue at this point.
I am out of deductive reasoning to find the issue.
I have had this truck for a while, and I do all the maintenance on it, and have never had any light, or electrical issues. I am not sure where to start with this problem, and I dont have time, or money to buy parts, and test things with no positive findings. I need help with this issue, and any opinions or help is greatly appreciated!
Jumpshot12
