Post:All lowered tahoes 4dr and 2dr
1999hoe
aka HOVERHOE
Massachoochoosetts
i think we all wouldnt mind have a reference point so if you could post pics and also a quik summary of your parts and drop specs would be great ill be posting mine on next tuesday...
Perhaps we could get this stickied in this forum
HuskerHoe
1999 4wd Hoe, McG's 2/4 drop(keys, shackle's and hangers). Titan 18's on 265/60/18. Summit special drop shocks, soon to be replaced with Belltech Nitro's.
imtbear69
Fresno,Ca
4/6 drop,Belltech springs, drop spindals and shackels, Belltech nitro shocks, tires are Falcon 225/45/17 on Boyd Coddington Stingrays
clean454
ahh yes my hoe again! LOL
ummm drop keys up front like 2-4 ish
flip kit on the rear and shackles about 7 inches :)
and its gettn bagged reall soon
rear
branndon_b
Lake Charles, LA
i'm thinking some 22's or 24's, probably 22's, and drop to make it look good. but at the same time i don't wanna go too low to where i can't tow my boat. then again, i've been debating a roll pan with a hide a hitch, which i'm thinking is a higher receiver hitch since it's not below the bumper anymore, and behind instead. so maybe i'll pick up a couple, 3 inches on my hitch height, which would let me drop accordingly in the back and remain at the same height. but then i gotta contemplate losing the spare to do it... decisions decisions. i'm probably just overanalyzing like i do about everything, to the point that i often lose interest before i follow through. so often it's not a matter of lack of means, just more a lack of decision making on my part. oh well. we'll see what happens.
HuskerHoe
I'm dropped with factory hitch. I use a 2" drop hitch but flip it upside down, 2" up. I've pulled an 8000lb trailer a couple times no problem. Never used my spare tire in the 3 years I've had it so I got rid of it. I also have one of those 250psi compressors that you plug into your cigarette lighter.
I wouldnt heitate to pull a 4000lb boat with a hidden hitch and some helper bags. Buy a little compressor, ditch the spare and dont look back
branndon_b
Lake Charles, LA
i guess my boat hitch is just kinda high, cause i use like a 5 in drop hitch i think, flipped. and it settles out kinda level when it's on my truck. as far as i know i'm factory height, doesn't look lowered. maybe my rear springs are tired? but that's the only thing i really pull with it, the only heavy thing, anyway. (22' bay boat). it might just be tongue heavy, no telling. haven't pulled much stuff in general, so i dunno. anyhow, thanks for the info. didn't mean to threadjack it. branndon
Low97tahoE
i saw somewhere on here that you were riding without a notch or somethin...i was wondering, did u ever notch ur frame, and also, how did it ride without the notch...i am doing a flip kit for my 4/6 drop and i wont have time to notch the frame until the next sunday...so i imagine ill be hittin the bumpstops alot for a week or so, lemme know how it was for you without the notch. thanks
AtomicHoe094
Atomichoe094
cleveland, OH
i have a 2/2 on mine right now, youve seen my hoe enough. But next week itll be around a 4/6. ill be sure to throw some pics up here with the powdered rims and shit.
Low97tahoE- put some pics of your truck up, i love your truck, always look at it on Cardomain.
Low97tahoE
Here are the requested pics. Ill be putting on the Flip kit Friday, ridin dirty for a little while and then doin coils soon after i get my exhaust ran again. (had to cut the tailpipes off to go 4/6.
HuskerHoe
low97, follow the rules!!!! Stats man!
Lol just joking. What are the details on the hoe though. 2wd I'm assuming? Tire and rim size?
clean454
i havnt notched yet
it rides ok a little bouncy take the bump stop bracket out when u do the flip kit
the bracket has a bolt on one side and a rivet on the other just take the bolt out and spin the bracket to the back and it will be out of the way
unless u want to drill or cut out that rivet
good luck
HuskerHoe
clean95, what about upfront? I know when I was decranked I was sitting on the bumpstops. Is there was to get more front travel out of these? Even after cutting bumpstops?
clean454
um well i have 22s and fender flares
and i dont have mine decranked all the way
but i did COMPLETELY cut out the bump stops ***** is low
---------- Post added at 09:22 PM ---------- Previous post was at 09:21 PM ----------
Low97tahoE
[QUOTE/] i havnt notched yet
good luck [/QUOTE]
i have already cut out the bumpstop bracket, i just cut into the head of the rivet a little and then hit it with the air chisel, then grinded it down flat, and punched it out. thanks for the info
WITCH1975
