Steering Wheel Control Lights
jjrmather
Olathe, Kansas
Steering Wheel Control Lights - Finally Fixed...........
The steering wheel control lights do not work. I am talking about all the lights not just a bulb or two. All the controls function fine they are just not back lit. I need to know if this is the BCM (body control module) and if so do I need a new one or can I have it reprogrammed at the dealership.
Thanks,
Rob
I found the answer. There is a 2 amp fuse located under the dash. This fuse is inline and cannot be replaced. If you follow the link below it gives a detailed description and pictures as to where the fuse is. I went to Radio Shack and got a blade type fuse holder, cut the old one out, soldered in the new one. It works great and with a fuse holder if it goes out again I can replace the fuse easily. Here is the link,
http://www.duramaxforum.com/forum/h...14764-fuse-steering-wheel-control-lights.html
Hope this works for you.
Rob Mather
vatahoelt
NoVa
Thanks,
Rob
the bulbs have burnt out. can either try to replace them or buy new switches.
J
jjrmather
Olathe, Kansas
I don't think it is the bulbs. I had one burn out and I replaced the switch. I then had another one go out and I replaced it but noticed that all my lights were out. Removing the new one (thinking it shorted) did not fix the problem. It would be strange to have all the control bulbs burn out at the same time.
Thanks,
Rob
vatahoelt
NoVa
I could be wrong, but I don't think that the bcm controls any lights.
kms_dude
Saint John, In
if its the steering wheel controls for the radio is probably the bulbs. ive replaced mine twice already. you can take a solder gun and change the bulbs ive done it
J
jjrmather
Olathe, Kansas
I realize how to repair the bulbs and how to replace the switches. My issue is that ALL, every single switch/control light is out. Not just the radio ones but the info center ones also. I need to know where the power to the steering wheel lights comes from.
Thanks,
Rob
moquin2
Rob, how do you replace the switch. The burndt out bulb is the lower left on the wheel. I have the switch.
Craig
J
jjrmather
Olathe, Kansas
Rob Mather
WITCH1975
