View Full Version : leaking fluid
supergreen
01-13-2012, 09:39 AM
I have a 96 4wd Tahoe, a/t ,with a whipple supercharger. The s/c was installed before I got the vehicle. It has 52000 miles. I noticed smoke coming from driverside rear engine area after turning off motor. Smelled like antifreeze. I crawled under vehicle and notice red fluid on bolts extending from bellhousing on drivers side. Any suggestions on possible fluid and cause of leakage. I have parked the vehicle and am waiting out an onslaught of rain that has plagued my part of the country.
purple 'hoe
01-13-2012, 04:15 PM
Red=Transmission Fluid.
Post pictures of said leak. It might help more. Also, move this to the correct forum. You'll have more luck there.
domin8
01-16-2012, 05:02 PM
To help localize the leak you can install a dye to show you where it is coming from.
ezdaar
01-16-2012, 05:10 PM
front seal on trans maybe leaking just bad enough that the converter is slinging it around..
Your antifreeze in radiator isn't red by chance is it?
vBulletin® v3.8.7, Copyright ©2000-2012, vBulletin Solutions, Inc.
