Fiberglass Fenders
BlizzardX23
Sacramento, California
yhst-17120696680161_2062_1856518
thinkin bout buying these for the 'Nali
some may think its dumb...but I've ripped so much rubber off my tire...and ripped my fender down at least 5 times....this would help...might look good depending on how well I install it...it would be unique...I know its for the pre-runner trucks..but still...
---------- Post added at 07:17 PM ---------- Previous post was at 05:50 PM ----------
anyone have opinions??
tybardy
everyone needs a Hoe
Gilbert Arizona
omg NO.... i mean i just dont see this looking anywhere near good on that nali bro!
you will have to remove some of that molding too...
i say..... NO
BlizzardX23
BlizzardX23
I need to flare my fenders out just a bit...
everytime I hit something that causes my wheels to tuck, It rips the inner lip of my fender down and out...it slices through my tire, cuts tread clean off...
the entire edge of my tire (ALL THE WAY AROUND) and been sliced off...I have deep cuts through the tread, some of the corner tread has also been sliced off...Im talkin 1/4 inch thick
I do that every time I tuck the front... hitting big bumps fast, driveways fast...stuff like that...
I already know the response (stop driving like an ass...or ... shouldnt have lowered it so low...blah blah) Im not asking about that...just about flaring out the fenders maybe an inch or so...that would eliminate the problem :)
Travieso
Boooooooost !
Los Skandeles, CA
hmmm that's weird i've never experience that even with my big 24's 315 Width tire i have never tear any of my rubber all the way around....
tybardy
Gilbert Arizona
yea i was thinking the same thing, im pretty sure my front end is lower then your blizz and I have never had a problem. I wonder if you have a goofy offset or something.
How much do those fender cost + paint? If its pricey, you should just sell your rims and get something with a more appropriate offset...
of course maybe you just need front suspension work
BlizzardX23
BlizzardX23
Heres pics of how it is while sitting flat
The camber is not even that bad anymore since adjusted....but, negative camber would only HELP in this situation..so thats not the issue
Look at all the tread damage...
This is how high the fender sits above the tire normally...
Here, you can see the fender lip that I have banged back into place multiple times
tybardy
Gilbert Arizona
yea you are sitting lower then i thought... i wonder what the other guys are doing to prevent this, i mean JK, Max, FatnLow all have REALLY low trucks... but thats a lot of nasty on the tire
BlizzardX23
BlizzardX23
I know Max said hes running more narrow tires...I dont want that though...thats why Im trying to find an alternative... =/
Yes, it is a 3-5 drop
Front = 3 - 4 inches (drop spindles with new torsion keys)
Rear = 5 inches (drop springs with drop shocks)
AtomicHoe094
Atomichoe094
cleveland, OH
Yikes! that sucks for your tires to be ripped up like that. what exactly is the term "rolling your fender" would that help at all in this situation??
BlizzardX23
BlizzardX23
I was thinking about that....I believe its curling the lip up and in so the tire doesnt have anything to catch and rip/slice on.... that is one option though
AtomicHoe094
Atomichoe094
cleveland, OH
thats what i thought, but just making sure, fiberglass would take off some weight tho.. maybe raise up your truck just enough to make it level..
Travieso
Boooooooost !
Los Skandeles, CA
why not go with a skinnier tire ? like for example 295/285 then you probably wouldn't have that problem, Idk putting them fenders on your truck is gonna make it look like a lifted truck
BlizzardX23
BlizzardX23
Because I dont want thinner tires in the rear...I want as wide tires in the back as possible... I cant stand narrow tires on trucks...I'm only running 305s on the front/rear...if I go more narrow up front, I wont be able to rotate the tires...ever! I already cant rotate them from side to side...only front to back...
otherwise, if I was going to go that route, I'd get narrows up front, and like...375s in the rear
tybardy
Gilbert Arizona
JFC bro, 375's!!!
305 is what i am running and they are plenty wide. You would always run a narrower non directional tire so you could rotate them side to side. however rotating side to side is pretty much worthless.
JamesinAbilene
