Violent front wheel shake, sometimes...
FunFordCobra
1997 Yukon 2wd 4dr. Sometimes when I hit a bump, one of the front wheels starts shaking pretty violently...Braking doesn't help..veering left to right does help it stop. This only happens on rough roads.. Smooth roads are fine and the front brakes and bearings are new. Wheels are new and balanced.
Any ideas before I start tearing things apart?
Thanks!
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Very worn chassis or steering part. GET OFF THE ROAD before you take one of us with you! Did this occur after the previous repairs or before?
FunFordCobra
FunFordCobra
Took it to just breaks and worked fine for a few months where they replaced the front brakes and bearings. It's not my only truck and it's been parked. I've had a tie rod end break on me in my younger years on my Z28 so I know the danger. When that tie rod broke I dont remember any shaking prior though.
FunFordCobra
FunFordCobra
Turned out to be the Idler and pitman arm.
Anyone know what the steering sensor is called? I'm wanting to replace that too.
Thanks.
retorq
Kingman AZ
I had that same violent shake with mine, the idler and pitman arms were sooo baaaad is wasn't even funny.
JamesinAbilene
