View Full Version : 2008 Denali Gains Intake & Custom Tune
Finally I did the tuning to my Denali!
Mods: Vararam Tri Power Ram Air Intake, Custom Dyno tune
Its not been easy because of the economy, but I managed to do before and after dyno's like I promised.
The dyno was a Dynojet AWD
Peak awhp could had been better but Intake Temp was @ 115 F and very humid still,
Here are the results:
This is in STD
Stock: 295.39 awhp 330.25 awtq
Intake: 318.81 awhp 348.43 awtq
intake + custom tuning: 328.53 awhp 355.92 awtq
Peak gains
INTAKE GAINS: 23.42 awhp and 18.18 awtq
TUNING GAINS: 9.72 awhp and 7.49 awtq
COMBINED: 33.14 awhp and 25.67 awtq
now this is where it gets radical:
In the hp curve in some cases I gained 60 awhp and more tha 100 awtq combined (intake & tune). With Tuning only it gained more than 20 awhp in some parts of the graph and 30+ awtq
This is simply awesome.
We noticed that the truck didn't loose hp all the way to 6400 rpms, so the truck now changes gears @ 6250 rpms.
I highly recommend the VARARAM intake and a custom tuning!
Hope you find this usefull.
stevek
03-01-2011, 10:53 AM
Interesting.
What gear did you use? 4th or 5th? They're 1.15 and .85 respectively...
2 E L O
03-01-2011, 11:32 AM
Interesting......The peak numbers are impressive for the minimal modifications.
Do you keep track of your average fuel mileage? I'll be interested to see how this affects daily driving and fuel economy. Below 4000rpm it looks like the gains are <20hp/20lb-ft....
Although definite peak improvements can be achieved, it drives me nuts to hear how people think they can get ~15% better fuel mileage just from a CAI and catback exhaust. That's just not realistic....
White07Tahoe
03-01-2011, 04:45 PM
Nice, How did it affect your MPGs? What makes that intake better than others?
BabyHuey
03-03-2011, 06:18 PM
Didnt expect such gains from the intake. How do you clean the filter, and how sturdy are the tubes that connect
Zed 71
03-04-2011, 10:35 AM
Thanks for doing the pre and post dyno. It seems like intake mods for the 6.2L yeild good results, gains across the rev band not just peak.
Now I am curious about the 5.3L; the gains will not be as large but wonder what the curves would look like.
03-04-2011, 07:41 PM
I'm a bit skeptical of the gains detailed just from the intake mod :think:
lt1z350
03-07-2011, 10:47 AM
I have seen similar with mine on a 5.3 but I got more from the tune and the volant cold air is about the same. plus seeing 4+ mph with my tune. really went after timing and dod settings on mine
Zed 71
03-07-2011, 10:57 AM
^ post dyno charts please :).
03-07-2011, 11:03 AM
:popcorn:
Interesting.
All runs where made in 3rd, 4th is too long.
---------- Post added at 05:42 PM ---------- Previous post was at 05:38 PM ----------
The thing is that our trucks (at least the 6.2L) run extremely rich (my truck was running 9.8 mixture OEM stock) so when doing the intake mod much more air gets in, hence more efficient. My MPG's improved almost 1.5 mpg city
---------- Post added at 05:47 PM ---------- Previous post was at 05:42 PM ----------
I can't speak for other intakes. I wanted to share with others my experience because, when I did my research, no before and after dynos where done, and even Vararam did not answer my emails.
---------- Post added at 05:53 PM ---------- Previous post was at 05:47 PM ----------
The cleaning is fairly simple, remove the frontal piece, three screws where the filter is and use the cleaning kit (green stuff) the intake has more than 40k and it still as good as new. A well made piece.
---------- Post added at 06:04 PM ---------- Previous post was at 05:53 PM ----------
I don't have anything to do with vararam. I don't get anything by posting outrageous numbers, I don't sell anything related to GMC or GM. This are my results. However, like I said, the 6.2 comes very rich OEM, and the intake increases air intake, so you can expect gains from this circumstances.
There were no before and after dyno's so went ahead and did them, with the happy results. If there is someone who is considering a intake, this is what I gained with this particular intake. I am sure that someone could get more gains than me, because each engine is different than the other.
bmwme
03-08-2011, 01:16 PM
The K&N looks nice but I don't trust the filters since I've heard of some allowing very fine particles pass.
The VARARAM tri-power looks like it was designed on purpose and if these numbes are right pretty impressive. Does it take up a lot of space in the engine bay?
How do these compare to the Volant 15253?
emann_01
03-08-2011, 02:57 PM
http://tahoeyukonforum.com/forum/showthread.php?t=5493
install pics can be seen here
Zed 71
03-09-2011, 10:09 AM
The thing is that our trucks (at least the 6.2L) run extremely rich (my truck was running 9.8 mixture OEM stock) so when doing the intake mod much more air gets in, hence more efficient. My MPG's improved almost 1.5 mpg city[COLOR="Silver"]
I am not familiar with the 6-speed. So is 3rd gear a 1.0 ratio?
Also at an air/fuel ratio of 9.8 that is really low and I am surprised it came like that from the factory. I wonder if your engine tune is an anomoly. No air/fuel ratio on the dyno chart? Just curious what they looked like.
Oh yeah, what are your butt dyno impressions?
Thanks again for getting your truck on the dyno :).
This is what I found online about the 2008 Denali:
First Gear Ratio (:1) 4.03
Second Gear Ratio (:1) 2.36
Third Gear Ratio (:1) 1.53
Fourth Gear Ratio (:1) 1.15
Fifth Gear Ratio (:1) 0.85
Sixth Gear Ratio (:1) 0.67
The mixture so rich is how they come from the factory, why? I really don't know, but I do know that they all come like that.
Zed 71
03-10-2011, 10:19 AM
Hmmm... those gear ratios are not dyno friendly. That is, the ideal ratio is 1:1. So your numbers make a little more sense. The power loss from the crank to the wheels was lower than expected for AWD dyno. But in the end the relative increase in power from each mod should be the ultimate focus. Good gains.
Tonygxp
03-10-2011, 04:14 PM
i am waiting for a call back from my guy but i don't think mine was that rich from the factory. my guy uses this dyno.
http://i111.photobucket.com/albums/n141/TonyTBSS/dyno002.jpg
my truck was 308awhp/315awtq and only went to 315/327 post tune (both same day hour apart) thre tuned runs all simliar that was the middle run, first was higher, last lower. runs were made in 3rd as well, a 4th gear run showed no difference stock but the run was waaaay too long for our taste.
the biggest difference from stock to the tune was the trans tune. that alone is worth a good .2-.3 in a 1/4mi imo, racing cars/trucks for almost 20 years.
congrats to the op on the gains.. btw my engine is an AFM engine, not sure if any cam profile changes were made? and if you didn't know the AWD mustang load bearing dyno ramps up resistance to mimic aerodynamic drag and the actual weight of the vehicle so it is far more accurate than a dynojet. it will always show lower figures and higher gains when compared to a mustang dyno.
matt_TuneTime
03-10-2011, 05:19 PM
Given the High ambient temps your Cat Over Temp was giving you the 9.8 a/f [ normal it's to protect the stock cats ] So your overall gains would be alot less with the COT off ... OEM A/F is 11.8-12.2 ... That being said the Vararam is a nice piece and combine with a tune I'm sure it feels nice and strong ...
vBulletin® v3.8.7, Copyright ©2000-2012, vBulletin Solutions, Inc.
