How-to 07+ Escalade boards on 00-06...Part 1: Driver Side...
Physh1
Ok, I'm breaking this up into 2 parts. Rumors of this being a bolt on mod with a little trimming is not accurate. To do this correctly, bolting up everything, this is simply NOT a bolt on upgrade.
The driver side is not hard to do with the right tools or access to the right tools...just requires some sectioning & welding. The passenger side will be a totally different animal. I will likely have to hybridize the stock brackets with the Escalade ones in order to clear the ac lines & securely bolt the board into place. Part 2 will happen when I decide how to hybridize the brackets of come up with a custom solution.
Part 1: Driver Side Running Board...
This is by far the easier side to do. No ac lines to contend with & plenty of room for removal & installation.
Removal, sectioning, welding, re-installation = 3 hours or so of work...
Tools needed to remove & reinstall the driver side stock running board...
3/8 rachet w/ 4"-6" extension
10mm socket
10mm combo wrench
T40 Torx socket
Chop saw or grinder with cut-off wheels
Welder
Hardware needed to reinstall the driver side Escalade board...
4 of the original T40 Torx bolts...
4 3/8" washers for T40 Torx bolts...
4 of the original 10mm nuts & bolts...
4 1/4" fender washers for the 10mm hardware...
4 1/4" standard washers for the 10mm hardware...
1 original 10 mm bolt (no nut)
The driver side running board has 6 support brackets & 11 total bolts holding it in place.
-these 6 brackets are bolted to the underside of the body using 6 T40 Torx bolts.
-there are also 4 10mm nut & bolt combos accessible on the underside of the running board & under the body. You'll need your 10mm socket & combo wrench to remove these.
-there is also 1 10mm bolt on under the front of the running board by the driver side wheel. There is a body clip here...no nut.
Board removed. Escalade board in front...stock in back. Notice the Escalade board only uses 4 brackets...not 6...
Here is one of the holes in the body the 10mm nuts & bolts go through. The bolt goes through the board from the bottom, through this hole, then the nut secures it above...
Stock board/bracket on the right, Escalade board/bracket on the left...notice that the stock brackets have 1/4" holes for the hardware...the Escalade boards have HUGE provisions. This is why we need to use fender washers with the stock hardware to make things fit & be safe...
This is the hardware you're removing...T40 Torx bolt on the right, 10mm body bolt on the left...
The body bolt locations on both boards are the same. You can use the stock hardware but washers will be needed. With the Escalade board held into place with 2 body bolts you can see we have an issue with the Escalade brackets being too tall. These, at this point, cannot be bolted up...
Here is the hardware I'm using. The T40 bolt (right) now sports a 3/8" G8 washer. I replaced the 10mm nut & bolt with 1/4" G8 hardware as mine looked a little rough. You don't need to do that BUT you do NEED washers! I used a 1/4" fender washer & a 1/4" standard washer...
In order to bolt the board hangers to the body each bracket has to be sectioned. In my case, from front hanger to rear, they needed to be sectioned 1", 1", 1", & 1.5". Here is the stock setup...
Here is 1 bracket with the 1" section to be removed marked in blue...
Two sectioned & ready to get welded...
All 4 sectioned, welded, & ready for install...
Sectioned brackets now bolt up to factory locations...note the washers...the T40 bolt head could slip through the bolt slot on the bracket...you can clearly see the body bolt as well...I replaced mine but the factory hardware will work perfectly fine with washers too!
Underside of Escalade board...
Driver side board re-installed with 9 total bolts. These boards have a much better build than our stockers, better brackets, & only 9 bolt holes. No more needed...
Cameron
chip
Cincinnati
Excellent job Sir! Great write up! (Too bad I just put boards on!)
Nice!! Thanks for the write up so that others may decide to do this mod and know what it takes :waytogo:
Physh1
Physh1
Part 2 is coming soon...weather has been to crappy to get under the truck to install the passenger side board.
Physh1
Physh1
Ok guys...
Part 2: Passenger Side Running Board...
This, by far, was a PITA to do. AC lines to contend with & lots of trimming & grinding the sectioned brackets.
Removal, sectioning, welding, grinding, clearancing, & re-installation = 4 hours or so of work...
Total install time for both sides is 7 hours...
As stated in the first post, in order to bolt the board hangers to the body each bracket has to be sectioned. The passenger side sectioning is identical to the driver side. From front hanger to rear, they needed to be sectioned 1", 1", 1", & 1.5".
Now comes the tricky part. The AC lines are not run straight along the body. They are curved & contoured oddly around body mounts & body lines. I did manage to trim, grind, & modify the sectioned brackets enough to work & not rub the AC lines. This takes time & patience but I don't think you want to be replacing rear AC lines. Each bracket needed unique trimming...no 2 ended up alike...
All the hardware info from the first post is the same.
This is what the sectioned brackets look like before trimming & grinding...
1rst bracket...after making it fit...
2nd bracket...after making it fit...
3rd bracket...after making it fit...
4th bracket...after making it fit...
Installation is the same...
The Tahoe is filthy but you get the point...
Cameron
alacran
bump for a great mod. i just mite be doing this some time soon
saldana17
Green Bay, WI
I see you talked about a running board change.
Did the new ones stick out farther than the stock ones?
Did you do the 07 Escalade mod?
2004 Yukon is difficult for my wife to use the stock boards. They don't stick out far enough.
Also 17" tires don't help. She is the primary driver.
I will plow snow with this vehicle but with my extra set of 16" tires more aggressive thread pattern.
Thanks for your answer.
Pachanga02
Ny
I need to save this. I might be able to get some escalade boards
boozer
Wichita, ks
my advise, use his measurments just for a guideline. when i did mine i had more grinding and cutting to do. but them measurments got me really close. passenger side is a PITA!!!!! LMAO but i love them!!
05Single
afraid of the dark
Revived! A lot of step pad/running board talk lately. This is what I'm talking about when I told a few of you on here that nnbs steps look amazing on our nbs. Nice sleek and low profile look.
iTahoe
Do not assume these amounts to be cut are the same for all years. I did it blind while my Tahoe was getting painted and when I got it back the measurements to cut were too much. In fact I don't know that they even need to be trimmed at all for an 06. I might actually be forced to buy all new brackets now. Lesson learned.
alacran
I would cut them and weld a bar to them before buying new brackets
JamesinAbilene
