View Full Version : rattling noise coming from front left 98 tahoe
montec313
01-14-2011, 09:54 AM
i had this noise start out by once and and blue moon then it does it everytime i go over a bump regardless if im turning or going straight. it got worse when i hit a curb playing around. rim is not bent and everything looks alright. it is really anoying and very loud. have to creep through parking lots just for it wont make the noise. any ideas???? gonna look at fixxing it this weekend. need heads up. too cold to be playing around outside. lol
retorq
01-14-2011, 10:59 AM
I would check the brakes and bearings ...
SunlitComet
01-14-2011, 11:41 AM
loose sway bar mounts, bushings or wheel liner? any loose items is storage under hood.
montec313
01-14-2011, 12:16 PM
Looks like the upper ball joint on the left side is going. Ball looks like it's coming out n the boot is ripped
SunlitComet
01-14-2011, 06:53 PM
easy fix then.
brooks93
01-23-2011, 05:39 PM
mines doing the same thing. did you ever figure it out
montec313
02-05-2011, 12:34 PM
ok i replace the upper ball joint and the shock on the drivers side. it seemed tio calm down. but there is still a poping noise coming from under neath the front when i go over bump. it does it to when going down the road turning the steering wheel side to side. any suggestions.
---------- Post added at 12:34 PM ---------- Previous post was at 12:02 PM ----------
i found what the prob was torsion bar link is broken. drivers side
SunlitComet
02-05-2011, 09:05 PM
ouch. I hope you meant sway bar link.
montec313
02-11-2011, 02:31 PM
no it is the link at the end of the torsion bar in the back of the vechile. the part was 37.00 from the dealer
SunlitComet
02-11-2011, 03:04 PM
Okay I know which one you are talking about now. I bet that will be fun to do.
Disturbed
03-02-2011, 01:53 AM
I have seen that the Bushing on my control arm is pretty warn out and I am thinking this is the culprit of my noise I am having, might wanna also check that out if you haven't.
vBulletin® v3.8.7, Copyright ©2000-2012, vBulletin Solutions, Inc.
