Wiring up fuel pressure gauge?
destroyer1362
A work in progress
Midlothian, TX
Where do I need to connect the fuel pressure gauge? I know where to connect the sender but where in the fuse panel is everyone connecting the the power sources and what else do I need to do this? (extra wires, fuses, etc.)
Pics would be helpful :)
destroyer1362
destroyer1362
A work in progress
Midlothian, TX
To answer my own question the #7 fuse can be used for constant 12v power and #6 for the switched 12v source.
grnrpr68
Davenport IA
dont go to the fuse panel have seen lots go wrong there if you want 12volt constant or 12volt swithed go to the ignition wires under the dash just my .02
WITCH1975
