Weird Transmission vibration
2018TahoeDad
Kentucky
Has anyone experienced transmission vibrations in lower gears that seem to go away after gaining more speed? I have a 2018 Tahoe with a little over 105,000 miles
Marky Dissod
"TSB Seems To Fix 8-Speed Automatic GM Transmission Problems
As of July 8th, 2019, GM began using a new type of Mobil 1 automatic transmission fluid for the troublesome transmissions.
Customers that complain of shuddering and harsh shifting characteristics in the 8-speed GM transmissions are recommended for a trans fluid flush.
As of August 7th, GM dealers should also be flushing all potentially affected new vehicles on the lot.
According to TSB (Technical Service Bulletin) 18-NA-355, the latest update addresses “torque converter clutch (TCC) shudder conditions on 8L45 and 8L90” eight-speed automatic transmissions, RPO codes M5N, M5T, M5U, and M5X.
The issues with the 8-speed GM transmission are two-fold.
First, some customers report the transmission shuddering frequently.
Secondly, the shifts are very harsh between first to second, and then second down to first, especially when accelerating and the transmission is upshifting or decelerating and the transmission is downshifting.
These conditions are most commonly observed under light and medium throttle applications, and as often during full throttle applications.
However, a new fluid flush appears to fix the issues, with some customers beginning to report a dramatic change in shift quality after swapping out the old juice.
If the flush doesn’t fix the issue, the next step may be to replace the torque converter, which could be glazed."
Ceegarz
