SnowDrifter
- Joined
- Sep 5, 2016
- Posts
- 2,407
- Reaction score
- 2,597
So after doing some reading, I've convinced myself that an external transmission filter I line with the cooler is an appropriate way to squeeze more life out of the thing and cut down on wear.
Ultimate plan is this:
1-2 micron filter on the output side of the cooling loop, pre cooler.
Filter attached to a housing with an internal 5-10psi bypass valve such that flow rate or a plugged filter or whatever will never be a concern. Realistically the bypass is not needed, but it's cheap insurance
Where I need help is, I'm trying to locate such a housing. I know they exist. My keyword searching just sucks. Anyone have any resources?
Also need to figure out which line is the output, and which line is the return on the trans. Anyone know?
