Blackcar
- Joined
- Mar 31, 2018
- Posts
- 665
- Reaction score
- 566
Are there any owners of the 8-speed transmission that are not having problems with them. Especially after TSB for transmission fluid change.
Well, not to jinx myself, but mine seems to to operating generally " normally" for its build date ( NOV 2014 ). Mine is a 2015 Yukon XL Denali. I had a new torque converter under warranty at 86K miles. I do a Mobil1 blue label fluid and filter change about every year. And by "normal" i mean that I accept a occasional clunky or lurchy 1-2 shift operation and an occasional lurchy / abrupt downshift upon highway acceleration as normal characteristics for this transmission. 98% of the time it shifts fine. i currently have 307,200 miles on it.Are there any owners of the 8-speed transmission that are not having problems with them. Especially after TSB for transmission fluid change.
so, this December will be 8 years of ownership. So its about 38,500 mi per year. Never used a "flush". I do my own work. Just drop the pan and install new fluid and filter. It has the 158 degree trans cooler thermostat. I did have to also replace the temp sensor harness twice. I consider myself a conservative driver and of course most of my business travel is highway miles.So 7years and that mileage changing every year looks to be 43000 miles a year. Did you do flush every year or filter and fill?
