Good cam?
Mrwick_02
So I'm building what is basically an iron block ls2 to go into my 03 Tahoe (LQ9 short block, 799 heads). Wondering what would be a good cam to put in it? I've always wanted to use the chopacabra cam from tsp but I wanted to get second opinions from people that have more experience in this field than me. What would be a good cam to make 400-450hp and sound pretty good for that short block/heads combo? Truck has a fully built 4l60e with trucool 40k, 4.10s with a trutrac, new transfer case, and fully rebuilt front diff. I will be running the stock intake manifold. Will consider getting heads/intake mani ported. Will also be running speed Engineering 1 3/4 long tube headers.
Mudsport96
40.923,-89.488. Illinois
Are you talking 400 wheel or 400 crank? With just long tubes and a good tune a stock LQ4 should be close to 400 crank.
How to make 400hp with a gen 3 truck engine
jump to 11:40 for the 6.0 stuff. Now this is an LQ4 and with headers and a good tune ( and minus accessories) it made over 400hp. So a higher compression LQ9 could do it with accessories. An LQ9 with 799 heads making even more compression should definitely be able to do that. So just the stock cam and go drive.
Now an aftermarket cam that makes more low-end torque is going to create higher cylinder pressures in the lower revs. Combine that with higher compression and you have a recipe for detonation. So premium will be required. So maybe get bigger injectors and tune for e85.
M
Mrwick_02
Sorry for the super late response... Preferably 400-420 whp.
M
Mrwick_02
The answer to this question really depends on how you are willing to prepare the rest of the valvetrain.
Sorry for the late response... Going with ls7 lifters, tsp chromoly pushrods, ams performance stock rocker arms with upgrade bushings... Not sure on springs as I haven't decided on a cam.
M
Mrwick_02
If it means anything, I've done some research and a sloppy stage 2 cam seems like a pretty decent cam but wanting to hear what others with more experience might have to say.
M
Mrwick_02
What are your plans for the vehicle? Towing? Racing? Just more usable power?
More usable power, racing, donuts/burnouts. Will be mostly daily driven, but I do race and do donuts/burnouts usually about twice a week.
M
Mrwick_02
Truck Norris cam. More average power through the whole range and only giving up power at the very top of the rpm range. In a heavy vehicle you want more low and middle torque.
Would a chopacabra cam suffice?... That's the cam I originally had in mind before I even started the project.
Jmily8474
